Paradigm Tweeter Diaphragms For Mini Monitor V2 And CC-370 V2
Nightwisher
Farer In The Goldilocks Zone
Paradigm has informed me that they are out of stock on V1-V4 tweeter diaphragms. Since I have 3 speakers that need them, I was wondering if anyone knew of any other sources of replacements - Parts Express, etc. Something that will at least get them going again. Paradigm suggested buying new Monitor SE speakers, but I just want to repair these if possible.
Thanks in advance!
I went through the same thing with my V1 Mini Monitors. I got the same answer from Paradigm. Their best advice was to either buy new speakers or try to find used ones. I ultimately found a used one on eBay. I paid too much for it but wanted to get the correct diaphragm.
You might contact Madisonsound. They sell replacement diaphragms for Vifa tweeters that do fit the tweeters in my V1s, not sure about the ones you have. The terminal spacing is different so you will have to slightly modify the faceplate but they do work. https://www.madisoundspeakerstore.com/vifa-voice-coils/
You might also check with these folks https://www.audioproz.com/AP.php?Prod=Speak_Parts .
Good luck.
Good luck.
Unfortunately, V2 and above are not Vifas. There's a pair of V2 tweeters on eBay I saw but they wanted like $160 for the pair.
I have a 7seMkII tweeter diaphragm around here somewhere. Does anyone know what other Paradigm models used the same one? I no longer have Paradigms. Vague notions, maybe, but no paradigms.
