MickeySmile
Well-Known Member
I am listening music from RH84 SE amp with the Cornwalls and the sound so good.
However, when I use it with other un-efficient speakers, around 89dB, the sound isn't good. Here my questions:
1. Can parallel single ended amp overcome this problem?
2. How more power the parallel SE amp deliver compare with SE amp with the same type output tubes?
Please educate me! Thanks for your knowledge and sharing!
However, when I use it with other un-efficient speakers, around 89dB, the sound isn't good. Here my questions:1. Can parallel single ended amp overcome this problem?
