Oh, that's cool. Looks like you fed it a 1Khz feed. What are you using to measure the output?
I have done some listening and... sounds sooo good!
I can hear more details in passages that have low-level but high frequency content - that is usually masked by higher-level mids.
Like I can pick up a cymbal decay longer when it is "under" a loud guitar or voice. Grand piano tones sound more natural also.
Of course this is my personal opinion. Most of my music is classic rock, and I am listen trough Grado headphones.
The Parasound D/AC-2000 is my main DAC along with other matching Parasound components from that same series. Tell me more about this D20400A clone: is it for sale and how much does it cost? My unit is working perfectly and sounds amazing, but I'm interested in this just in case the D20400A ever fails.This is the modification of one of the three Parasound DAC2000 models. The old one did have heat problems because it was a melted chip and with the use of 24bit signals it got more problems. Antonio an engineer from Italy replaced the original chips by used only the original Ultra Dac’s chips that are also used by Parasound on an own made PCB. Now after 100 hours playing I measured it with a non modified and also this was a unbelieveble step up in sound. Antonio worked 15 years on this chip.
Hi Karl,The Parasound D/AC-2000 is my main DAC along with other matching Parasound components from that same series. Tell me more about this D20400A clone: is it for sale and how much does it cost? My unit is working perfectly and sounds amazing, but I'm interested in this just in case the D20400A ever fails.
There's a Chinese chip designer who has recently released a D20400A clone as well. His company is called Datel and he calls it the D20400PLUS. It can be found on ebay.
Also, I posted the following thread about my D/AC-1100 and the PCM63P-K chips I just ordered from ebay from a Chinese seller with 12,000 transactions and 100% positive feedback. This thread had very helpful information from @SoNic67 about how to distinguish fake PCM63 chips from real ones. I am praying that the ones I ordered are real:
Upgrading Parasound D/AC-1100 to PCM63P-K
The Parasound D/AC-1100 is the unit that got me into the late 90s line of Parasound components and was my first external DAC. A local record shop let it go for $75 and I was hooked. Since then I've gone down the DAC rabbit hole, spending untold hours reading about the different chips, R2R vs...audiokarma.org
