Parts Express' locking 90deg banana plugs - best way to use?
MOEB74
This is my first time paying more attention to stuff, audio wise. I bought some 4s11g and Im going to make some cables. The cost was about 40$ more than the basic speaker wire I was going to buy. I also splurged on some of the PE 90 deg locking banana plugs, since they seemed like they were worth it.
What Im wondering is about terminating the 4s11g into the banana plug. Should I tin the leads? Should I use a wire ferrule? Do I use one screw to hold the insulation of the wires and the one screw to hit the conductors? Both screws into the conductors?
Any other pointers?
Thanks!
Personally I would make sure both screws were in contact with the conductor. This ensures the best mechanical and electrical connection.
I would also tin the wire first but that is simply the way I do it. I feel you get a better bite as the screw deforms the solder.
Using a copper ferrule will not increase the resistance enough that it could even be measured. At least with a standard DVM. It will however increase the size, perhaps to the point it may not fit in the hole.
If you tightly twist the bare wires before inserting in the hole, you won't have any issues. If tinning, or using a ferrule makes you feel better, then do it.
