Parts express speaker kit
Jeff banker
Has anyone built any of the kits from parts express? I thought it would be a good project for my son and I. Just want to make sure they aren’t total junk.
I've built a couple. The Overnight Sensations do sound pretty good, but they are low sensitivity and you have to be careful with the volume especially if you are heavy handed with the bass control. The other kit I built was the BR-1's. It comes with a PCB for the crossover and the cabinets are pre-built.
You still have to solder up the crossovers, cut and glue the foam,wire it up and mount the speakers. The BR-1's sound nice. Plenty of low end and the silk dome tweeter is detailed and smooth. I've been using them at my bench system. It doesn't have tone controls and just don't need them with these speakers. I like them.
The Tritrix looks to be a good kit. The solstice kit is supposed to be real good but more expensive (over a thousand for kit but does use morel drivers
What a great idea for your son! If he's going to use it in his bedroom with a smaller system, I like the suggestions of something smaller like the Overnight Sensation. Could be a set of speakers he takes to college (if he has plans, maybe too young), but would be a great father/son project. Learn how to solder, how to do a little wiring of cross-overs. My first project was an AM/SW tube receiver kit made by Graymark in my 7th grade shop class. Next thing I knew, I was building Dynakits........
Thank you! He is 13 . And I’m self learning audio repair so I thought it would be a good project. When I came home he had the Catalog out of the box from things we ordered from parts express and showed me it. We have collected a few things since we started this so these will be used in his room. Now we just have to choose which kit.
If it's for a 13 year old, something with grills may be a thought. I remember being pretty rambunctious at that age. :D you can always get replacement drivers from PE pretty cheap though if one gets damaged. The midbass drivers for the O.S's are about $14 each. I had to replace one. I use the O.S.'s as test speakers at my bench. One got fried by a damaged amplifier.
Do you think they are of higher quality?
Swan makes great drivers! I have some. Incredable build quality for the price.
Yep, and there are all kinds of posts over the internet about how to even go farther and make improvements on them...
The original Totem Forests used a HiVi driver in the bass position, I've got a couple of them in a box in a closet waiting for a project...someday...
Well, if your son is deeply involved in the construction of the speakers, might he not be a bit more careful about how something he created gets treated?
