pissboy
Its good to be the king.
This is more of a vent for me than anything else, but a few of you may smile and laugh knowing you have been through this before.
Yesterday my driver's side outer bearing decided to give up the ghost and fail on me (2004 Ford F150 SVT Lightning). Luckily I noticed it on my way to pick up some brake parts at the auto store. After about 40 minutes of working with the parts guy I had some bearings, brake pads, brake hardware, and brake hoses. I headed back to work and started pulling the wheel and calipers off so I could pull the hub/rotor assembly. Of course my truck is from the salt belt, so I broke a ratchet trying to get the calipers off. It took 2 chisels, a sledgehammer, a cutoff wheel and a punch to get the bearing apart and get the hub/rotor assembly off. The hub/rotor assembly had some pretty severe damage, so it was off to the parts store again to pick up a pair of hub/rotor assemblies. After chiseling the inner race off of the spindle I found that it had melted and recast in a few areas due to the heat/friction. It was no use trying to repair it so I set out to find a replacement. Come to find out.. no one made aftermarket spindle/knuckle for a 4x2 F150.. unless you want lowering or lifting spindles. New from the dealer would run me $360, but I'm going to take my chances on a $65 salvage part. After giving up on the driver's side I moved to the passenger's side. I spent the previous day spraying the passenger's side bolts with PB blaster so the caliper came off a bit easier. The bearings and rotor/hub assembly were in great shape so I decided I wouldn't swap those out and went to work on the brakes. I got everything apart and then unpacked the brake hardware and pads only to find out they were the wrong parts.
I now know what I'll be doing tomorrow after work and likely Sat morning.
Attached is a photo of the bearing before I had to (further) destroy it.
I now know what I'll be doing tomorrow after work and likely Sat morning.Attached is a photo of the bearing before I had to (further) destroy it.
