jocko_nc
Thanks to AK I am soon to be in the possession of two telecaster necks NOS from Musikraft. Early 2000s. These will be CNC blanks, with several raw fingerboards. Thus, the degree of difficulty for this build is going way up. I thought I was done for a while with electrics, but this opportunity was too tempting. I had considered a stratocaster in candy apple red for my son, but really it was just a thought. Now, I am going to try it.
I am going to be on the prowl for a body or two. Damaged. Dinged. Whatever. Something to salvage. Something cheap. The finish is going to be lacquer paint, so I will be able to fill or repair whatever I need to. With all the bodies out there, I am looking for opinions and recommendations. I do not know about the different types out there. Squire. Bullet. Affiniity. Starcaster. MIM. Korea Strat. Japan Strat. ???. There is no reason to choose anything valuable. The neck will be a Musikraft custom, so how would anyone even know if a body is MIM (not that I would likely spend the money) when the pedigree is on the headstock? A better body might come with better hardware, but good strat hardware is everywhere. Even used. I can mix and match. People change pickups like socks, so great used pickups can be easily found. New tuners are a given. The necks are pilot hole only so I can choose anything. 18:1 mini Grovers are always nice. No tremolo.
I know the neck pocket dimensions will be critical and a potential pitfall. It must be 100% on spot or else I will consider the project a miserable failure.
This is really an opportunity to fool around with a three coat candy apple red in nitro lacquer like the original hot rodders did back in the 50s. Early Spring works well for painting in the garage. It could come out fantastic. It just takes effort.
What would you guys do in this situation? Help me out please with some ideas.
Thanks.
Thanks.
