Checkylad
Thinking about buying a Canton Plus C subwoofer to add to my system. Will it perform as well using my approx. 2004 era Denon AVR-687 or should I use a dedicated amp for the Canton Plus C
Are there any advantages to either scenario? What is the minimum wattage needed to make the sub "sing" well?
The Canton says Western Germany on the back so it is probably from right before the Wall came down in Berlin.
In either case will the sound be better than with an active sub?
