I am still not convinced, in case I don't have DAC right now, why not to choose the hiface DAC over USB-SPDIF adaptor and DAC separately.
the hiface DAC has 384khz/32Bit which is way over the standards. it has dedicated drivers to bypass windows drivers and it removes the use of cables between the spdif to the dac (which in some cases will reduce the quality)
This is good advice - asynchronous is best reason. If DAC is asynchronous then should not need SPIF converter. Mine is not.
