Pc2002m ground switch
70barracuda
Getting some hum through my speakers, and in the Yamaha instructions for the pc2002m it says you can turn off the ground switch on the back to eliminate the hum. Before I do, is there any issues it would cause? I'm running a pre amp into dual mono pc2002m using the xlr connections.
Does not appear to be any safety issue. The switch simply "breaks" the connection between in the input/xlr GND pin and the amp chassis GND.
So try it and report back. If hum still present then determine hum frequency, either 50/60Hz mains hum or rectified 100/120Hz. Mobile phone ap like spectroid or ... or you can record and upload into freeware audacity or ... May help to localize cause.
So turned the amps on with the switches off and got a super loud hum. Turned off immediately and put switches back to on. Still a low hum. Used the app mention and it's a 120hz sound.
Weird thing is it's only when the second amp is turned on. Doesn't matter which one, once the second is turned on the hum starts.
  • Like
Reactions: mbz
Oh ! ..Nevermind.. :biggrin:
How about running the power amps on two separate AC circuits ?
Oh..Nevermind.. How about running the power amps on two separate AC circuits ?
Can't try that right now but I will be adding a separate breaker and outlet just for my system so I can try one on each once it's all done.
Fish tank with heater, filters, air pump etc on the same circuit...
Possibilities ..
Did either amplifier have input power issues or modifications ?
You get the hum with inputs (xlr) connected or without? If you’re on xlr getting the hum, try unbalanced inputs or no inputs to see what happens …
Suggests after rectification???
A bit of a reach but could it be that the GND from PC(1) is significantly different to PC(2) and GND loop by xlr's back to pre?
Turn off that GND switch on any one(only) PC amp and retest.
What pre are you using?
