battradio
Electron trainer
The Peerless 1609 output transformers are known to be less than reliable in the Heat Kit W-5m .
Is it the transformer itself or the way it was used in the circuit , i have one w-5m amp and plan on getting another that looks like it has been rebuilt but still has problems so i'm assuming that the output transformer is flaky . Haven't checked the output on the one i have but if either of them or both are bad i will have to replace the output transfomers with something reliable .
I have a pair of output transfomers that came from Eico HF-20 which look like identical to the power transfomers and are the same physical size which won't fit where the peerless are mounted :tears:
That leaves me with several choices , find a decent pair output transformer to fit in the peerless cans or mount the Eico' output transfomers in place of the power transformer on the Heath chassis in place of the power transformer and put a power transformer that fits where the output transformer was , or strip the entire chassis and make the the Room for the two large potted transfomers that match .
The W5-m chassis makes no sense how it was laid out the power cord comes in by the output transformer and the input and driver tubes are right next to the power transformer and the output terminal . So both the relocating schemes s makes sense to do except to a real purest .
Re stuffing the can with a new transformer makes more sense to me than having something rewound that wasn't dependable to beguin with .
Mark
Mark
