riponfrosh
Hey all. I just picked up an absolutely stunning Blaupunkt Rio Deluxe. It is gorgeous. I was told by the PO that it didn't work. I got it home, plugged it in, FM works great. All speakers work great. The main issue is the PE 66 turntable in it is in dire need of a new motor. The bearings in it are toast. The pe66 has an odd (to me) idler wheel setup and the shaft for the motor that is supposed to contact the idler is toast. You can grab the main shaft coming through the motor and wiggle it in/out/and all about. The motor will just grrrrr unless you can pry the shaft into the perfect spot.
Anyway, my question is can I...
A) find a replacement motor for the PE66
B) find a replaement PE66
Or
C) will an any other turntable fit into the same spot in my Rio Deluxe currently inhabited by the PE66
I can't find much in the way of info or parts for the PE66. Any info or input about the PE66 or the Rio would be GREATLY appeciated!!!
Or
