FrankFIII
While the RP-117 has been working fine without a problem, one thing that was bugging me was the display light for side "A". While I did originally find a replacement, the bulb I originally used was not as bright as I though it should be. I went on the hunt and located some bulbs at https://www.jacksonelectricsupply.com/ . This site has a lot of bulbs. I eventually found a "DA613 T-1 1/4 Special Axial Lead Lamp 12V .055A" . I pulled it apart yesterday, put the new bulb in and put it back together. I think it took me about an hour to do the job. I am much happier with the appearance of the display. It has a nice green glow when on the "A" side. Luckily, I was able to re-use the original green vinyl sleeve that Sharp used on the original bulb. I simply slid it off the old bulb and on to the new one.
