Cantabury Guy
I can't seem to find a source for a set of 6 footers ,only 12ft. Any good sources.
Thanks
Thanks
Thanks
Thanks
http://www.sjgreatdeals.com/pet10-5010.html
But unless you're using them intact, from a price standpoint it makes more sense to buy the 12' and cut them in half.
Right, tell it to the judge.I just went back and clicked the link and ...6ft. I am not that lazy that I didn't try that site before, but only the 12ft. length came up?
That is correct.So I just was about to pull the trigger on the cables. So if my thinking is correct, if I order 2 six foot set, I will actually have 3 L/R sets. One for my TT to pre amp, then preamp to amp. Then I could use the other discarded video cables as a L/R from a tape deck?
I ordered two 6 foot Petras on Tuesday. It's Saturday and they arrived today. My 2 main tables have RCA outputs, so I connected only one to see if I could hear a difference. :yes: I then used the remaining piece from one cable cut in half for my Marantz with the butchered cable job. These things really work great. Thanks Howard. I still have another piece left to use on the next table...My set of Petra's have been installed and in use for a few months on my TT and they sound great. I'm now running a different power amp/line stage combo that does not have a phono stage built in and will be buying a dedicated phono stage (likely the Cambridge 640p) so I can listen again to vinyl. Since I'll be ordering a new set of Petras for the Line Stage to Phono Stage connection (per the recommendations above), I'm also in need of a new set of interconnects from my CD/DVD player to the new line stage.
Can the same Petra cables be used with similar success/sound quality in the digital domain? I see others are using the Petra's equally well for tape, but anyone using them CD > Preamp/linestage?....and how do they sound?
Thanks,
Mike
OK, a thought. it seems that maybe the best plan would be to leave the pcb alone, and instead connect it to some chassis mount rca jacks. thoughts?
thanks howard. have you ever de-soldered/soldered new cable to the technics pcb? i know you're deep with technics know-how....
