mslayer
One woofer was missing. (misplaced after pulling a long time ago to re-cone), So I needed a pair. That's why if you notice 4 of the 8 mounting screws are silver. My son carved out the spacer needed between the woofer and the cabinet with a CNC.
Tweeters were ok. Used the original mounting plates on new drivers.
These were in my garage for 15+ yrs one had been a good supply of insulation material for a varmint. Had to replace that also. A little tricky in the lower chamber but done. I am also looking into the Grill foam material. after some research I think it is reticulated foam. It is used as filter material, But I cannot find it in large enough pieces and it comes in different textures depending on the hole size Like 10-20-30 PPI. I think the correct size is 30 PPI . NOT CHEAP! So I need to find a sample to see if it is correct and can be shaped easily.
They sound great. I did a lot of searching for the replacement woofers. I even contacted Phil Clements. Nice guy. He wanted to sell me a pair of his latest designs. Yikes! $$$!
