yTweeter technology has come along way (particularly the power handling of domes) -the AMT's were way ahead of their time.
The Peerless plate tweeter was very good IMHO-Midwest has a reproduction. Like the CTS, they were somewhat fragile, especially with lower power/clipping receivers etc they were generally paired with back in the day (Magnum 100/etc-although as I recall they were the cheaper versions)
At $250 for the system-they had to be Omegas-as the 1 1/2's were at least $200 ea retail-but you can always upgrade......
Most of the DLK's I have ran across used the Mexican version.
The reproduction (4 and 8 ohm) have a slightly higher db output in practice.
Most of these speakers sound ok at best in their stock 40 year old condition.
New caps-as well as damping-the stock stuff is worthless in it's age.
The green basket long throw rubber surround woofers in the 1 1/2's were IMHO were their best woofers and hold up well to abuse. They just need the proper damping and the bass cleans and deepens right up ( DLK never added enough damping even when new as the boxes are slightly too small for the( 2) 8" woofers specs).
The 2's often used a cloth surround woofer-watch for the VC rubbing. It can be fixed easily if it hasn't gone too far. They could not take the abuse the 8" green baskets could.
The 2's also benefit form replacing the stock stuffing with a piece of 2" acoustic foam-again make a big difference.
As well as the Tweets.
Always wanted to try a small Heil with a set of the 1 1/2's......
Spent a lot of time @ Schaack back in the day-loved the H/K stuff. SoundWorld too (now Besy Buy) but Schaack was more fun-as well as the sales men.
Different world now for sure-even with puffy jackets back in style! This cat sticks with is Carhartt....been their done it....Can't say I miss the polyester paints and satin shirts with like 3 buttons...
Still dig Kojak though....ah except for his signing...
ADS were decent back in the day as well-the dome tweets set them apart, muck like Polk.
Most manufactures figured out decent enough clean bass/midbass- by the 70's- the mids and highs is what set most really good of the day speakers apart from the average...
Not to mention most midrange electronics (magnum 100 etc) didn't have the best bass drive nor damping and failed to really control the woofers to give you really clean bass-even if the drivers were capable. H/K the exception among others.
Upgrade thoughtfully, drive them with some good power and get some surprising results--AMT3's included as well!
