Philco Console Amp...
Should I use the filter cap values you have drawn on the PS for the Zenith, or use the PS, but connect to the Philco multi cap values? I would probably raise teh capacitance a little,, my goal is to get the amp as clean, and quiet as possible,,,given its limited power ..
As always, I appreciate your time and help,,,
Regards,
John
Thanks. Use the cap values and circuits Philco used. Nothing special about the filter caps and resistor between my filter caps in my circuit, it's just a generic example. You can use higher values, as the rectifier is SS you can use larger values with no worries about stressing a tube rectifier. Oh, and be sure you use at least 200V caps, as the B+ will be higher (around 170VDC at least before the tubes warm up) than with the old tube rectifier.
Thanks for the reply...
I need to order a couple parts, IT's for sure,, then I can build it,,, I got this amp sounding pretty good, with the original design,, changing teh 12AX7 made a big difference... I am also going to try to twist and dress teh heater leads when I rewire it... I have 250V caps clipped into it now,,, I'll replace them all with at least 200V when i order them...
I just cleaned up teh schematic, so I can read it, and it looks like teh primary load on the OPT is only 270 Ohm,,,the 35C5, and 50C5 are both 2.5K,,, think its a misprint on teh schem, or am I missing something?
Thanks again for having patience with me... I'm gettin' there!!!
Regards,
John
I just cleaned up the schematic, so I can read it, and it looks like the primary load on the OPT is only 270 Ohm,,,the 35C5, and 50C5 are both 2.5K,,, think its a misprint on the schem, or am I missing something?
The 270 ohms is likely referring to the DC resistance you'd measure with an ohmmeter. Not related to the AC impedance, which would be 2.5K for the 50C5 and 35C5s.
However you can approximate the impedance of a speaker by measuring it with an ohmmeter, then you multiply what you get by 1.2 and that would be the AC impedance. DO you still have the original speakers? They were probably 3.2 or 4 ohm impedance.
Oh, and 250V caps will be fine, unless you wanted to save them for another project down the road.
No,, I just got teh amp,,, I would guess they are only 3.2/4Ohm,,, the Zenith is... OK, I figured I misread something about teh resistance of the OPT,,,, the 50C5's should almost be a plug and play after teh K resistors and PS are sorted out...We had a discussion about replacing teh OPT's on that amp, AES had some 2.5K/8 Ohm OPT's for 5 bucks, but I missed them... Timing is everything...
I'll order some new caps for it, when I get the PS dialed in,, I'm not sure on a couple connections on your schematic, as to what pertained to teh Zenith, but I'm studying it,,, I'll use teh DBT to keep teh short ckt damage to a minimum!!!!
Thanks again for your help...
Regards,
John
One thing I outta mention, to reduce the chance of ground loop hum, be sure to connect the resistor that is connected to the negative (-) side of the bridge rectifier directly to the same point in the amp where the filter cap's negative wire also connects. Doing this should keep the ripple cap recharge currents out of the chassis ground and the rest of the amp. This cap recharge current otherwise can induce unwanted voltages and introduce a buzz into the amp.
Thanks for replying,,,
I rewired teh heaters for teh 50C5's,,probably teh hardest part of teh job,,, its tight in there!!!
I have been studying your PS plan,, I did figure the B- went to that negative point, thru a 20W resistor and a .047 cap (or is the cap from teh Zenith, as I see it's on teh Zenith schematic) ? Thats also where the center tap from teh 12AX7 heater terminates also, correct? I see it goes thru a .047 cap firs, but thats part of your PS, correct?...
These two amp schematics are just close enough to be confusing,,,
Got the caps , bridge and resistors ordered,,, just gotta find teh Iso transformers,,, and maybe a fresh pair of output tubes...
Regards,
John
I have been studying your PS plan,, I did figure the B- went to that negative point, thru a 20W resistor and a .047 cap (or is the cap from the Zenith, as I see it's on the Zenith schematic) ? Thats also where the center tap from the 12AX7 heater terminates also, correct? I see it goes thru a .047 cap firs, but thats part of your PS, correct?...
Sounds about right.:thmbsp:
I got teh transformer, (Triad N68X), bridge, and some of teh caps I needed over the weekend...
I tried running the amp, with the trans wired in reverse, with two separate windings and "normally",,, It sounds best wired normally, however, I can't separate teh B+ and heater string, with only one winding. Wired in reverse, I can only get 104V out, which is low for the heaters,,, and only about 110V B+... it also has a lot of hum and distortion... Not gonna cut it, unfortunately...
Wired normally, gets rid of teh distortion, hum is still there, but its pushing teh outputs to about 144V,,, which is what I was going for...The heaters are a little high, 127V, but I think I can lower that with a pair of larger resistors,,, I still have 6-7 caps to replace, when they get here, and then I'll tackle the hum...
Thanks for the help so far,,,
Regards,
John
I just read a thread about proximity of switches, fuses, and AC in general, to the signal path of an amp... One of teh replies mentioned that bridges were a common cause of noise in amps,,, If that is true, how would I go about reducing hum, with teh Pos and Neg leads on a bridge so close together??
I have teh heater string tightly twisted, and run against teh chassis,, and tied to teh AC leads on the bridge,,, it was the most convenient spot to put them, without running even more AC around teh chassis....Is it possible this amp would have less noise with a half wave diode, or even teh original rectifier tube?
Learning more every day!!!
Regards,
John
Wired normally, gets rid of the distortion, hum is still there, but its pushing the outputs to about 144V,,, which is what I was going for.. and then I'll tackle the hum...
You'll need to find if the hum is a ground loop issue, or heater cathode leakage, or maybe the new power transformer is leaking magnetic hum fields into an input line or the output transformers. Various test you can easily do: with clip leads, connect the output tube grids to ground. Hum change? If it went away, then the hum is getting into the driver tube or the inputs. If no change, then a bad or miswired filter cap, or a ground loop issue, or the magnetic pollution I mentioned. Try unmounting the new power transformer, and carefully rotate it in various directions (assuming the leads are long enough to allow).
The filter cap's negative ends should go directly to the negative terminal of the bridge (via a resistor is okay), but not to some spot on the chassis some distance away. You want to keep the filtering currents out of the chassis, those currents can cause hum (known as a ground loop).
Hi again,,,
I did a little more work on it today,,,, the caps I ordered Tuesday got here already,, so I replaced them... I kinda got teh hum out by grounding teh input jack common (right now, its just hanging on teh input cable, teh jacks aren't mounted to teh chassis), to teh DC - , bypassing teh .047 400v cap... This jumper makes teh hum almost nil at 0-1/2 volume,,, and then I can hear it a little as teh volume raised, at approx 80%, the hum disappears... Is there any reason I shouldn't jump out this cap, or is there some other problem I'm missing?? I guess this means its a ground loop issue,,, However,, I will try your other suggestions, this amp is going to sound pretty good, when its all sorted out,,, lots more volume with teh 50C5'S running at 145v,,, and I replaced teh 33ohm heater string resistors with 47ohm, to lower teh filament voltage...
I put a larger filter caps in, gotta find room for teh 3rd one, may put it on top, so it can connect right to teh bridge,,,, but thats just "finish work" gotta kill teh hum completely first....
Really appreciate your input, and it seems the PS you sent me worked out pretty good,,, I didn't count on teh trans being buck and boost, but, I think I got around that problem....
Regards,
John
... bypassing the .047 400v cap... This jumper makes the hum almost nil at 0-1/2 volume,,, and then I can hear it a little as the volume raised, at approx 80%, the hum disappears... Is there any reason I shouldn't jump out this cap, or is there some other problem I'm missing??
Now that you are using the isolation power transformer, you no longer need that cap. Remove and jumper it out. The reason for it was to limit shock current from the amp's days as a hot chassis.
Sounds like you have the amp working well.
Thanks,,, I appreciate all your help, I will take that cap out, and either jump it , or just move teh input ground to teh neg ground lug,,,, Do I need any different caps to protect the input,,, There a 1/2 meg resistor across the input jacks,,, whats that one for?
Where should I look for the last bit of noise, from the volume pot position...
Regards,
John
I'd insert caps on the signal input lines (and remove the half meg resistor, not sure what it did, maybe some stereo mixing, but you won't miss it), to keep stray DC biases from your iPod or whatever from getting into the 12AX7 grids. Caps around 0.1 uF or 0.047 (reuse that 0.047 if it was a new cap). As for the hum pickup at some positions of the volume control, you may need some more shielding on the volume control wiper connection. Maybe a metal plate across the bottom of the chassis will take care of it. If not, an easy way to do this is to use some solid core thin insulated wire (solid holds its shape better) and wrap it around the wiper wiring (including resistor bodies and such). Easily undid if it didn't help.
Thanks for your reply,,, I will remove teh resistor, it just connects teh L to R input at teh jack,,, but, I think you mean put teh caps from each input, to teh common (ground braid), correct?
The pic is a 100uF 3V cap, its parallel with a 4700 resistor, that takes teh 12AX7 cathodes to ground. It was marked + at one end, and was split, so I replaced it with a 25v lytic, it was all I had that was polarized,,,does that sound like a good replacement? Will changing the values of either, help with hum, or distortion, tone, etc...
I changed teh .047 600V cap (2nd pic) with an .068 630V Orange drop, (had it on hand),,,it takes teh NFB to ground,,, I think these two caps may be critical to teh sound quality, if not noise, as they are in teh input circuit... Should these be exact values, or different kinds of caps?
I'm trying to understand how these different types affect teh sound, distortion, noise,etc,,,
Thanks again for all your help...
Regards,
John
Thanks for your reply,,, I will remove the resistor, it just connects the L to R input at the jack,,, but, I think you mean put the caps from each input, to the common (ground braid), correct?
No, I meant that they should go from the center wire of the input shielded wire to the input circuit (that is, where the center wire now connects). Both channels,
The pic is a 100uF 3V cap, its parallel with a 4700 resistor, that takes the 12AX7 cathodes to ground. It was marked + at one end, and was split, so I replaced it with a 25v lytic, it was all I had that was polarized,,,does that sound like a good replacement? Will changing the values of either, help with hum, or distortion, tone, etc...
That should work well. Only impact is gain at the low end ie, bass.
I changed the .047 600V cap (2nd pic) with an .068 630V Orange drop, (had it on hand),,,it takes the NFB to ground,,, I think these two caps may be critical to the sound quality, if not noise, as they are in the input circuit... Should these be exact values, or different kinds of caps?
The bigger caps should extend the feedback to lower frequencies a little. But if teh tone control is inside the feedback loop, it may have less effect.
Thats how I connected teh caps,, one end of each cap together, to teh sheilded wrap, and teh other end of each cap to each center wire,,, however , i connected them at teh jack end of teh input cable,,, I think they should be on teh tag strip in teh amp, (I re read the input cap ckt you gave me, not sure I followed what you mean)... I'll take a pic...
On the 100mF cap,,, not sure its teh reason, but as the bass is increased teh volume goes down considerably...
I'm pretty sure teh tone control is in teh FBL,,,thru the 120 Ohm resistors, correct?
Thanks again,,at least Im learnin' what won't work!!
Regards,
John
The input caps should not touch ground. What you want to do is the cap tied to the center pin of the RCA jack, and the other end of the cap goes to the center conductor of the shielded wire. In your picture, that's the red wire. And the clearish wire for the other channel connects to a 2nd cap, and the other cap lead goes to the other RCA center pin. Actually better is to place the caps in the same electronic position but physically under the chassis.
RCA jack center pin------||----input to amp
RCA ground---------------------------amp ground
GOT it!!!! I must be thick as a brick,,, The diagram made it clear... Caps in series with input wires and center of jacks,,, makes sense,,,, I'll put them under the chassis....
Thanks again for hanging in there...
Regards,
John
