Hi guys,
A friend of mine recently brought me this integrated amp. It was about to be thrown out by the owner of a local bar, because both channels cut out one after the other.
So I took it upon myself to try and safe this nicotine brown workhorse.
Initial testing with headphones revealed that the right channel was weak and left was dead.
After replacing the transistors in the tone board and some elco caps, sound has been restored, but only when using headphones.
When I try to use the speakers, the fuses blew immediately. I checked the speaker connections, but nothing was wrong.
Even without any speakers connected (they use DIN two prong plugs btw), the fuses still blow.
Now, my question is:
Where should I start looking for the culprit?
Sound is fine, with watt meters working and everything on headphones.
Are there any common defects that can cause these problems?
The fuses blow on both channels simultaniously.
All help is appreciated.
PS: I'm very impressed by the build quality and clear lay-out of this entry level amp.
