Oilmaster
Sonycus Peritum
You're right, these are two different product lines. Perhaps like you mentioned, the US built Philips gear may have come from the former Magnavox factories. Looking back at your pics, a couple of building differences are clear. The US model has radial power caps soldered on a PCB, while the home market gear always had loose power caps binded to the chassis.
Two different models with the same designation, only seperated by the suffix....
The /xx suffix was normally used to define modification revisions, which were always very nicely pointed out in the service manuals. So when I purchase a Philips unit, the service manual nicely lists all modification which have to be accounted for compared with last built revision if you haven't the last revision. The Philips documentation of that era was very good maintained for that.
Too bad you may not (easily) find the 70's European Philips gear in the US, because main stream priced Philips gear does actually have lots of Class A topology. Because Philips really went for plastic chassis and front plates, they looked much cheaper then was actually inside it (e.g. check out the 22RH561, excellent unit). Therefore, like in the US I guess, they lost the commercial battle with the Japanese, despite that a Kenwood KA-3500 is 3 times less technology then the 'plastic' Philips units. We can buy 70's Philips units by dozens for $20 to $50 each (yep, even the ones with aluminium fronts), but few people like them... too bad, I bought some to strip them for homebrew projects. Hehe.
(if you are not familiar with it, make sure you download all parts by clicking on the 0,1,2,3 by 'multipart' in the next window).
