Fab9
Member
Hi everyone, I’m starting this thread because I was recently given the Philips 877 turntable mentioned in the title.
It seems to work fine, but it suffers from the classic and severe warped bottom issue. Not only is the bottom plate bowed,but the right side is deformed as well. It's so warped that the antiskating mechanism and the tonearm balance touch the base and don't work properly; however, if I loosen the screws and lift the turntable away from the base, everything goes back to working correctly.
I'll post some pictures in the next few days when I have time to work on it. In the meantime, I wanted to ask if there are any fixes to repair this, or if I'd be better off trying to find a used replacement base.
Thanks everyone!
Thanks everyone!
