PabloGa247
Hello everyone,
I recently bought a Philips GA-247 turntable and I’m having an issue with the idler wheel arm alignment. When I select the speeds, the idler wheel does not touch the correct part of the motor pulley:
I’ll attach some photos to make it clearer. Any guidance would be really appreciated!
Thanks in advance
- At 16 RPM, instead of touching the thinnest step of the pulley, the idler wheel already sits too low and touches a wider part, so the platter spins at around 34.6 RPM.
- At 33 RPM, it plays close to 45 RPM.
- At 45 RPM, it runs even faster.
- The idler wheel itself is fine (rubber is ok).
- The selector lever moves the arm, but the whole arm seems shifted downwards.
- The speeds are consistently off because the wheel never reaches the correct pulley step.
- Is there an adjustment screw or mechanism for the idler arm height/position on this model?
- Could it be related to a loose spring or pivot on the idler arm assembly?
- Has anyone here faced the same issue with Philips or other idler-drive turntables?
Thanks in advance
