This may not be a very helpful thread as the two turntables are very different, but just in case someone has had experience with both, I thought I'd ask!
I recently wound up with each of these after looking for something with a small footprint. The SL-Q5 survived being shipped relatively unscathed but the 312, no so much. The platter wasn't packaged separately so the tonearm wound up getting broken. I have a replacement off of a 212 but still need to have it installed and everything else likely needs to be tuned up. Fortunately, the belt hasn't melted and all the switches seem to be working.
The SL-Q5 has an AT V235EP cart with a new Thakker ATN 102 EP stylus. Sounds great to my ears and having it be automatic and not really needing adjustments has been really nice! I definitely will be keeping it as either a solid backup or one for daily use.
As for the questions, can the 312 be fixed up to the point of being a better sounding table? Or, are they distinct enough (sound quality wise) to warrant having both? How far can each be upgraded? As a side, the aesthetics of each won't make much difference, as I like both.
The cartridges I have for the 312 are a Philips 400 and an Empire 5000 MKIII. From what I gather, I can probably do better from a cartridge standpoint. My thinking is that if the 312 can be brought to the point of being a significantly better sounding (or at least different) table, then I'm all for going on the journey of fixing and tinkering with it. However, if the effort and cost is going to just get me about where I already am, then I figure I may as well sell it and upgrade the SL-Q5 as far as I can.
Any other points to compare and contrast would be greatly appreciated. Thanks in advance!
