PHILIPS GA212 - a couple of questions from someone with pretty much no technical ability whatsoever
steviechick
Hello,
I have a few questions about my Philips GA212 - I've read up a number of the other threads on the site but none of them exactly scratch my itch.
I got the turntable last summer - my dad had one in the 70s, and it became mine in the 90s when he ditched his turntable, though I then ditched it as the decade closed, "upgrading" to a frankly unremarkable and much lower-fi Ariston deck with my first proper paycheck. When the Ariston finally died last summer, I found a cheap GA212 on eBay, and was overjoyed with the sound quality at such low price.
However. It's always had a bit of a hum issue - mostly silent, but sometimes feeding back, and losing sound in the left channel. I put that down to the connection to the amp - it had a DIN plug, so I bought a connector with PHONO plugs at the end, but it seemed crackly and intended to upgrade at some point. I'm not entirely sure about how well grounded it is - I can't see a grounding wire, which I'm guessing is inside the DIN cable? Also, while the sound was wonderful, if the needle encountered any non-mint, non-recently-cleaned vinyl, it would skip, which made buying cheap second-hand vinyl a disappointing experience.
So, a few weeks back I purchased an AT-95E cartridge to replace the original Philips 401, and last night finally got around to installing it. The new cartridge, with its elliptical needle, is like Snowpiercer - it just bulldozes through the dirt and the scratches, as I wanted to. But there is a constant low-level hum now, which subsides a little if I poke my finger around the back of the cartridge, but never entirely.
The headshell has the kind of sliding carriage/sled with the copper connectors, if that makes sense? I'm tempted to take it to my local record player shop for the guy there to repair, but I'm on a tiny budget and also the guy at the shop told me last year, when I bought the DIN-PHONO connectors, that the repair guy doesn't work on Philips 212s as he thinks they're too finnickety. Is there anything I can do to solve the problem? Is this a common issue, with a simple-enough-for-a-simpleton cure? If I replaced the headshell, would that solve the issue, and would I have to get a vintage Philips headshell or would a generic one work?
Thanks in advance for your help.
Welcome to the AK turn table forum.
There is no generic headshell, that headshell design is Philips proprietary . :no:
I'll suggest cleaning the copper contacts both on the sled and the fixed portion of the headshell with deoxit or CRC contact cleaner. Also, clean the copper ends of the headshell wires that slip over the cartridge pins. Make sure all connections are dry. If you still have the hum, try slightly separating the wires from the catridge to the headshell a little farther apart from each other. Slightly rotating the connector on the cartridge pins may also help. I've had a recent hum issue with my 212 and all the above has eliminated it. Hope this helps.
Welcome to AK.
Enjoy the music,
-Mark
Thanks both of you.
While tinkering around with my stereo this afternoon I noticed that the feedback/hum continues even when the turntable isn't connected to the amp, but when the connector I use to connect to the turntable's DIN cable is plugged into the amp. So perhaps the issue is the amp after all? I definitely have further research in my future.
