Phillips 312 dust cover question
bmgc89
I'm looking to replace the dust cover for my Phillips 312 but not having much luck. Does anyone know if the dust cover from a 212 will work? Or if anyone knows what models have interchangeable covers. If anyone that owns a 212 would please reply with the dimensions of the cover, I would greatly appreciate it. Thank for your your time.
The 212-312 had a couple different dustcovers. Depends on the hinges. There are the friction hinges with a single pin from the hinge that goes onto the dustcover. Early 212s had different hinges and a kickstand to hold the table up.
I expect the single pin dust covers are the same for the x12 series tables.
Thank you, I found a 212 dust cover with the single pin hinge so I think I'll pull the trigger. Appreciate your help.
