Phillips 312 transistors
raffman
Hey gents, I am trying to repair a Phillips 312 turntable. Power supply is good. Motor not getting power tho. I noticed a transistor marked p736 (or p749) is burnt. I can’t remember which is burnt but I need both. Where can I source these? I checked mouser but could not find anything similar. I’m not too savvy so if someone could point me in the right direction I’d be grateful!
get the service manual from www.vinylengine.com free after you sign up, then find the items you need to determine the true identity of what you need, not the placement number.
then if you can't find an item on mouser, call them and they will help find what you need, either the correct one, or a substitute.
always liked the 212/312 series,
