Phono Pre-Amp for Thorens
cybersp780
Hello,
I am about to get a Thorens TD-160 and want to get a phono pre-amp to go with it. What is a good match for the Thorens?
I am looking to spend around $250 and was considering the Bellari VP129 but I am concerned with the hum people have been talking about. It will mainly be used to listen to through headphones and that's why I thought the Bellari would be perfect since it has a headphone amp. Any other suggestions would be appreciated.
Thanks.
No hijack intended, but I've never really thought about matching a phono pre-amp to a particular table. I always figured it was more important to match to the amp, with an emphasis on the type of cartridge (MM vs. MC) you would be using. Am I missing something? I'm planning on running my TD-160 with Denon DL103D straight thru my Yamaha CA-1000...
Well if it helps the cartridge it came with is a Shure RXT5, which I believe is MM. I am all pretty new to this so what you say might be right. Like I said it will mainly be used to listen to through headphones so that is why I thought the Bellari might be the best option.
You're right.
To the original poster, there's a few AK members who've had great results with the Bellari. It's a nice, cheap way to get some tube sound into your system. I've used the Pro-Ject Tube Box II and was very happy with it, but that's going to be about $100 out of your preferred budget range. Just buy the best phono preamp you can afford, don't be concerned with whether it's going to match you're turntable.
