Phono stage for AT MONO3LP question.
dmac
I ordered the AT MONO3/LP MC today. I am thining of getting a seperate phone stage as an upgrade to my Sony ES900GX receiver that I am currently using and I noticed that the Ohm load recomendation is 40-47 on the AT. Most of the phono stages that I am seeing have a MC load of 100 ohms like the Cambridge 640p. Does this matter? Will getting a MC stage improve anything over my current 47 ohm MM stage in the Sony for this cart? Phono stage suggestions would be appreciated. under $300 is the budget. Thanks Again.
Dmac
Hi,
The MONO3 is a high output MC. It's designed to work into a MM stage. BTW, that's 47K ohms. Most people seem to find that after a few hours playing time it sounds nice without changing the load resistance. Output is a little low for MM section so you'll have to turn it up a bit. It's a nice cart, especially for the money.
neo
Thanks,
I am setting this up as a mono only table and will need a second phono stage to do so without fooling around with wires. I plan on having two table hooked up to the same AVR for this setup. I see a inexpensive stage from Emotiva - XPS1 that has an impedeance adjustmet for MC carts and figured that I will get this, since I need one and would have the option of adjustment if needed. Any thoughts on that would be appreciated.
You won't need the MC section for the MONO3, but you might want it for future/other low output carts? The output of the AT might overload a MC phono stage. A regular MM stage is recommended, maybe one with a healthy amount of gain.
Phono preamps start around $50. If you go to Amazon you'll see a nice selection. I haven't heard the XPS1, but it has some good user reviews. It might be hard to beat for the money. I know of a couple which are pretty nice, but they're in the $300 range.
neo
