redpackman
These are the DLK 2 Generation 1 speakers, with the plain foam grille trim. Pretty rough shape, but they're DLK 2's so we'll see. Both of the tweeters are missing . Not totally sure if ANY of the drivers are original except the midranges (pictured along with the woofers) look like the type used in the generation 1 DLK 2's. The woofers have the dark dust cap with the lighter color cone (but not exactly white) with the paper surrounds. The woofers and midranges appear to be alnico's with both ends sealed around the magnet. See the posted pictures. All of them have good ohm readings around 7.1 ohms. The woofers have good "movement" manually. No scraping sound and "springy."
At any rate, anyone have spare Generation 1 DLK 2 tweeters they'd be willing to part with? Am I right in assuming they used CTS phenolic ring tweeters, now sold as the t-135? I'm going to check with Midwest Speaker Repair to see if they have any new/old ones, too. They've become quite expert at repairing DLK's because DLK's frequently turn up in the St. Paul area.
Also does anyone have a schematic or photo of a DLK 2 First Generation crossover? That would be handy. It's obvious when removing these speakers that some minor "experimentation" or mis-wiring has been going on.
