Picked Up The Heaths Today
hakka26
Banned
Saw a pair of Heaths a few days ago at a local TS. After doing a search decided to gamble until 50% Sunday. Still there got the pair for $4.00.
Heath AS-10. Nice wood veneer. Cracked them open for a look- 16 ohm 10" Jensens and dual Jensen tweeters. Look in great shape. Don't have the time to take out the zillion bolts holding them in. Will hook up to see there sound ASAP. Why the three posts with a wire jumper for the speaker connect? Also picked up a semi-homemade(?) box that had a 12" Jensen and a tweeter for a buck at a yard sale.
My AR's have the same 3-post connections. The jumper ties the woofer and tweeter inputs together. It simply allows the tweeter to be disconnected in order to use the speaker as a "sub" of sorts. - MA
Appreciate reply. Did a search and found a set (expired) on epay and saw the label that is missing. Pictured what you said.
Hooked the Heaths up with:
Yamaha CR 820-Sounded dull and flat
Kenwood 4200-Better, not bad
Kenwood Digital-Probably the best sound
Anyone have any specs? Apparently need some watts. Haven't put em with the Sansui Eight.
