The original spec was indeed 600 ohms, 270 mH inductance. Pickering later tweaked the body specs slightly to 700 ohms, 350mH.
Either I defied the odds of random selection (they can't all be great) or I have no judgment.
This stylus goes both ways--apparently nondiscriminating as it spreads its misery.
That's a great review, I was sort of wondering at first why you were maybe not going to use the old sxv 3000 cart , and was hoping you would toss a stylus on it. and listen for a while. So many people including myself are buying the new hype carts that sound clean and nice, but are "very refined with a gray shade " compared to the old carts , pickering to me reveals the musics mistakes also, the squeak in the saxophone, a ride cymbals center bell, sounds like actual brass pinging, not just a nice, squeaky clean high end. I am a big fan.Thanks for all the help. More may be coming — but I have the patience of a 2-year old. I couldn't wait.
I put the Stanton 881S stylus into the Pickering body — it's a better (snugger) fit than in its own body. I mounted it in my lowest mass h'shell, the SME cheesegrater. I didn't have a decent set of leads, just found 4 of mixed age, type, condition. Overhang off about .4mm (the SME h'shell has no adjustment) but I'll fix that later. Then into the tonearm at 1.25g (linear tracking, so no anti-skate).
BRILLIANT! Not just as a general superlative, but it has sparkle, dazzle, excitement. Its energy level reminded me of my Empire 2000Z, but better — OTOH the Empire is NOS and may change.
It jumped straight on to my favorites list. Surface noise a bit more than the cart it replaced, but that one has a NOS stylus. I'll play with VTA/VTF to see if noise improves. It may sound even better when I take time to dial it in better, but even if it doesn't change I'd be churlish to complain.
I don't understand how such an old cartridge kicking around in a drawer, not it a box or any other protection, and so corroded it wouldn't even make contact, could sound so new and alive. 3-4 months ago I found another cartridge I didn't know I had, ADC, and it also blew my mind. I'm very lucky — I have about 15 carts in all, 50/50 MM/MC, all vintage (over 25 years) and most NOS (so I'm spared the maddening stylus hunts). And with only one exception (Shure V15ivHE NOS), they all sound just GREAT to me.
I haven't used an LOMC for some time after using them exclusively for 25 years. I'm kind of afraid to — did I lose 25 years of joy (when my hearing was perfect) because I was suckered by the propaganda of "experts" for-hire?
I think that is probably a decent choice for $79.95 .02x.03 vivid line, i know its expensive but you are getting a real nice stylus, I have one similar breaking it in now, had never paid $80 for a stylus before the vividline, but I have bought $50 carts that I didn't care for, so its a ok deal, if you wanted to go even higher possibly the xsv 5000 shabita stylus would work on the 3000, I am not positive , it may not work, but that stylus is $129.so what would be the best available option for a replacement stylus for the xsv 3000 ?, is my only option the vivid line from lp gear ?
yes that's the million dollar question ,really cant tell you, know that the pickering stylus would probably sound more "pickering" than the vivid line, but you really dont have much choice today, I know by comparing my d750 with the vivid line, the lp .02x. 03 lets the cart show its stuff in maybe cleaner new style, but still pickering snappy.how does the vivid line compare to the original D300 stylus sound quality wise ?
I vaguely followed your exploration of ceramics a few months back, Joseph, but never took the plunge. But that was before I realized you are the Captain Kirk of cartridges. I must go back and review that thread and choose one... unless someone points me in a good direction. Are they all conicals, or am I way off base?You ought to try a nice ceramic cartridge if you like the unvarnished truth
Wualta, I think you're totally right about that freaky frequency plot and increased surface noise. +5dB at 12K? That's nuts! Is there any way to tame it? Put a resistor in line or something?Putting the D81S into the original 3000 body would, at least theoretically, give a curve that's not dissimilar to the curve you see in that graph in post 76, which would explain why you're hearing more surface noise.
Thanks Wualta. I have tone controls but not adjustable turnover points. I'll see what effect lowering treble has later: working now. "Other strategies" would be welcome... but not necessary if they require an engineering degree. I'll just enjoy the Pickering on quiet records!it's easily correctable should you ever want to.
There are other strategies.
you will find that most treble controls are in the 10-15khz range, its normal for carts to need a few clicks in either direction to offset varying cart or stylus eqs. i have a few carts with a high peak ,that sound best at almost a flat treble control, and some a little higher to get a similar high end.Wualta, I think you're totally right about that freaky frequency plot and increased surface noise. +5dB at 12K? That's nuts! Is there any way to tame it? Put a resistor in line or something?
But I still love the cartridge. I guess I'm not an audiophile.
For what it's worth, I found the old stylus carrier with brush. It has the stub of the broken cantilever, very accessible, not crushed, a perfectly round O just asking for a new cantilever. And I assume the tie-wire is intact (if there is one).
Now where do I find a worthy stylus/cantilever to graft on, without destroying a good cartridge to get it?
Yes, I have some MCs, which include their frequency plots, and show the characteristic rise above 10Hz — but a gentle slope, nothing as sudden and steep as that that rise you posted! Yet the sound isn't nearly that extreme — maybe they used a different baseline in those days to measure the frequency?Many megabuck cartridges have rising response above 10kHz. As long as it's a smooth rise, it's easily correctable should you ever want to.
Are you referring to the sound of the D81S in the XSV-3000 body being not-that-extreme? That's right, because the D81S doesn't have a misbehaving top octave the way the D3000 did, not even when you play it in the XSV-3000 body.Yet the sound isn't nearly that extreme — maybe they used a different baseline in those days to measure the frequency?
It really is an orphan cartridge, analogous to Shure's M24H-- unique CD-4able body, nothing works properly in it except the few stylus/styli made especially for it. That doesn't mean you can't experiment, of course. No harm will befall....can anyone tell me about the UV-15 ?
Clearly you have a large house.This is why it's so hard for me to get rid of anything. But slowly, I do. Little by little. Nothing I don't have a double of, though . . . not yet, anyway.
Collecting phono cartridges and styli takes up lot less room than collecting vintage appliances.Um, no. I collect cartridges. If one has a tendency to hoard, this is what you want to hoard. My vast collection still fits inside one U-Haul medium-sized moving box.
