Is the Pickering V15/ATE-3 Cart any good?
I want to know if it is worth getting a needle for it.
Is it in the same league as the Pickering XSV cart with the D-3000 needle?:scratch2::scratch2::scratch2: Or even close?? :scratch2::scratch2:
Thanks for your input.
Cheers
Not knowing what turntable/arm you are using makes it rather hard to answer your question. Entry level turntables can only give back just so much. The XSV line will require a decent turntable to provide you with all it is capable to give. The 2 cartridges you mention could actually sound the same in a lesser quality (think entry level), turntable.
Regards,
Don
You could get a conical for it like a V15AM and use it for older less than perfect Lp's or 45's and the AM stylus isn't as heavy a tracker. I'm speaking of the genuine pickering V15AM. I have a generic V15AM and it's nice stylus. got it on ebay for 7 dollars and i track mine at around 2 to 2.5 grams. I have the same table by the way and I use my AM with a stanton Gold boded 500Thanks for the input thus far.
The turntable I am currently using is a JVC QL-Y66F.
And yes, I'm using the XSV there as well as the original MC Audio Technica/JVC branded cart.
If it is not worth getting a new needle for it, I would give it to my nephew to play around with, as he is using a Mitsu DP-EC7 TT right now with a mediocre cart.
Cheers
I have a V15 body and got a Stanton D71EE stylus for it; essentially the same as a 500E mkII now. Very nice sounding, should be a good match for the DP-EC7 medium mass tonearm.
