Oh! Plants on the speakers!
Just using a plate still draws moisture from the air onto the plate then onto the top of your speaker since it ends up getting cooler than the surrounding air (that is how my RS4b was damaged) but a piece of glass under the plate should fix the issue. My wife has "Lego Botanicals" on the speakers in the bedroom, but they are nothing but plastic so it's fine:Yes to plants on spealers!
Plants should sit on a plate or drip tray and a sheet of glass though.
But my 615's have a plastic top anyway.
www.lego.com
Yes and a sheet of glass indeed (unless your speakers have a plastic top like mine).Just using a plate still draws moisture from the air onto the plate then onto the top of your speaker since it ends up getting cooler than the surrounding air (that is how my RS4b was damaged) but a piece of glass under the plate should fix the issue. My wife has "Lego Botanicals" on the speakers in the bedroom, but they are nothing but plastic so it's fine:
LEGO® Flower and Plant Gifts | Official LEGO® Shop US
Brighten up your home with a range of artificial flowers and plants made from LEGO® bricks. No need to water or feed, and they look great all year round.www.lego.com
Depends. First you’ll have to find them, but don’t worry they wear moving blankets 24/7.I’m a firm believer that nothing belongs on speakers. But, you be you.
My hearing goes to about the same level as yours and I am 52. There isn't much up past that anyway and most people don't make it to 20k anyhow.I wasn't a fan of the Klipsch sound growing up and hated horn tweeters, but these ears are 40 years old now and these speakers sound amazing to me. I can only hear up to about 15khz these days and I'm sure that a big part of it![]()
That turntable must weigh a ton!!!
Just 35 pounds, but it feels heavier. Sharp used Mikage granite. They also put a lot of travel in the feet, I'd almost call them articulated. I'm surprised I got it level without shims on this board.That turntable must weigh a ton!!!
It barely fits! Perhaps you should center it!! Looks great!!Just 35 pounds, but it feels heavier. Sharp used Mikage granite. They also put a lot of travel in the feet, I'd almost call them articulated. I'm surprised I got it level without shims on this board.
I like the stack of Schiit you have there too !
I tried it centered for the 1st mockup, The added weight directly over the support is more stable. Thanks for the kind words.It barely fits! Perhaps you should center it!! Looks great!!
Thanks, but it’s more of Schiit Schmear don’t you think? Reminiscent of the horizontal spread of the Beomaster system that I couldn’t afford (finance) at 20 y/o. I still have the M70 4 ways though.I like the stack of Schiit you have there too !
