Pilot 210 Scratchy volume pot. DC on the POT?
Just finished replacing the selenium rectifier, filter caps, and all the non- ceramic Caps in my Pilot 210 preamp. Thanks to all the posts here over the years, my lurking was very helpful as I finished the task.
Both prior to and after the recap, the 4 ganged volume pot is "scratchy". Sprayed it first with tuner cleaner/ lube. Gave it a second shot with non lube precision electronics cleaner then again with the cleaner lube. Still scratchy.
But here is my theory. I do not think it is a bad pot. I have noted lots of threads in various forums referring to their SP210 having a "scratchy pot" I think from the way it sounds and acts that, rather than a bad pot, I have "DC on the POT Syndrome"- DC crackle which changes if I touch the pot using me as a big capacitor) without even turning it.
I have fixed this problem in a lot of simpler guitar amps with new coupling caps. Here the major cap replacement has not fixed it, but there are a gazillion ceramic caps and old resistors I have not touched, and would rather not.... Since this preamp receives its' power from the 232 amp, not yet refurbed, there are even more potential errant DC sources one could envision, so this is not a simple Champ amp fix for me. If I must I can live with it as it sounds very nice and is only an issue when touching or turning the Volume pot.
I hope first I stir some sympathetic "me toos" from the forum, as many may have the problem and mistakenly start searching for what may be an unobtainium pot replacement. I would even better love to hear from the pros here if there are any common fixes like a small cap off the pot to ground etc. Thanks for bearing with the long post!
