Pilot 240 Schematic
archie2
Addicted Member
An AK member asked for this so I thought I'd post it for anyone else who might be interested. Not sure it belongs here but the moderator can move it to wherever.
Pilot 240 schematic and connection diagram. It's from the original owner's manual.
It looks like the 4 ohm output taps are grounded. What's the deal there?
Also, am I correct in assuming that using the speaker selector switch while the amp is running could potentially generate a damaging flyback pulse and should be avoided?
My pilot has slightly different output ports. I will post pics once my camera is repaired. (probably a week or so) Thanks for posting the schematic! :)
If you switch speakers while driving it into clipping, you DESERVE an arc-over... assuming that they used a break-before-make switch anyway.
The 4 Ohm winding is the center-tap - grounding it makes both + and - polarities available, which allows a center channel or mono output by connecting the two channels in series. The EICO ST-series and some others used this connection.
Hahaha agreed. Well there is no warning or anything on the chassis, which I understand because it's old school equipment. Though I wonder how many failures they had due to end users not knowing the risk there.
Ahh interesting! I just want to be sure I wire everything up properly.
