Pilot 245A...
Dylanl
I recently acquired a pilot 245A. I've had other integrated tubes units before but I always seem to like the pilot models.
The unit is stock and seems to run very well, just wondering if there someone on the forum that specializes with working on these.
What is the overall opinion of this amp?
See photo
I'm assuming it's actually a good unit. It was actually a Pilot receiver (not sure if it was a 402, 602, or 654) that my grandmother had that made me realize as a kid that some gear was just better than others. I currently have a 654 out of nostalgia but it has a few minor issues and it's also the only operational tube unit that I have at the moment so I can't offer a more up to date perspective. I would say it's probably a keeper though.
That's a great amplifier, and they are getting very hard to come by compared to the pilot 240. I think choosing if you'd like to upgrade or not comes down to your personal opinion. I would probably replace all the filter caps, replace all the coupling capacitors with higher quality caps (pio, or whatever your personal preference) and check for drifting resistors and see how it sounds
I have one that is a console pull and was passed along to me by another AKer. I have the schematic in my files. I can scan it next week and email it to you or post it here if you want. Attached is a picture showing the work that's been done to mine. A local tech did the work. I still need to have an in-rush current limiter installed.
Mine is paired with a refurbed Pilot FA 680. As multichamp12 noted this Pilot amp doesn't seem to show up for sale as much as others like the 240, 602, 680, 402 etc. Maybe more of those were manufactured? Dunno.
I have an ad from the March 1959 issue of High Fidelity Magazine I'll post.
I've offered before, if anyone has schematics that need to be scanned that are larger than 11x17 I have access to large format plotters/scanners at work and can scan up to 36 inch wide documents. Obviously I can't do huge piles but for things like a couple schematics I'd be happy to do it.
See photo
I've rebuilt these. One thing that seems to make a pretty significant difference, is to convert it to individual bias adjustment for each output tube. Makes the bass cleaner and very slightly louder. Getting the bias exactly the same for each output tube, really lets the output transformers do everything they can do.
It's crowded under there- and it's more complicated to do an individual bias conversion on these compared to others (due to the paraphase inverter, and the way it's set up), but it can be done, and done well, if you're determined enough.
Also, there's some resistors in the preamp stage, that seem to get WAY out of spec. Those need to be dealt with, to insure the same gain on both channels.
There's a LOT of B+ voltage on these- especially on 120v and with the stock 5AR4 rectifier. I wound up using a 5V4GA in most cases. Drops about 30v off of the B+... which put it into a "comfortable" range for the output tubes.
I went back and looked at my notes on the 245A- I had forgotten HOW MANY caps there are in there to replace. Like THIRTY of them or more!
The payoff is worth it, though. It's one of the most impressive EL84 integrated I've ever encountered, when it's done right.
Here's a picture of mine, with the wood case I built for it. That was a lot of work, but it came out very cool, I think.
index.php
More pictures here: http://www.audiokarma.org/forums/in...or-a-pilot-sm245a-tube-integrated-amp.594557/
Regards,
Gordon.
I totally re-capped a 245A a few years ago and ended up selling it when I came up short on cash shortly after finishing it. Wish I'd kept it. It was very sweet sounding. Many of the original kidney bean caps were leaky, but once they were replaced it really was nice. I even went as far as replacing the ceramic caps on the volume & tone controls with copper leaded silver mica and film & foil caps. Jim McShane had a screen supply kit I installed (also works in the 232) and the sound became even more clear & detailed w/o any harshness. I wish I hadn't sold the 245 and I keep looking for another one. I did pick up a 248, which will get the same treatment. Yours looks to be in very good cosmetic condition which makes the money invested worthwhile.
