Hello, folks,
This is my first post. Lurked for years to get valuable info about vintage tube amps and vintage turntables.
Now I'm starting my first tube amp project and I thought some here might find it interesting. I've attached a couple of pix with more to follow as I dive in.
I've searched the net high and low for info on this receiver and found none. I expect the astute among you will notice the chassis is actually a Pilot 602 of early 60's vintage.
Of course, the big question is why the complete re-work of the front controls. And I mean complete. The original 602 compliment of seven knobs is increased to ten with the addition of an AFC control, a 'Comp'(loudness?) control, and the splitting of the ganged treble and bass controls into individual knobs for each channel. Four of the slide switches and the input selector knob are replaced with a set of eight push buttons. The on/off slide is moved from the bottom left to the center between the channel controls. The tuning scales are moved toward the center and the tuning-eye is replaced with a new eye for each scale mounted at the outer ends.
All this means the old 602 front panel is replaced with a new one which is, as far as I can tell, a nearly production quality, hard chromed aluminum plate with engraved letters on the main control label band and on the bezel. The grid-pattern engraved skin is applied to the face plate with and intentional split between the right channel treble/bass controls. All in all, this is a pretty amazing re-working of the original 602 front end.
My first theory is that this a near production prototype of an RCA product based on the Pilot 602 chassis. I heard from Uncle Mike over at Vintage Asylum that this sort of prototype would show up from time to time in the South Jersey/Philly area since the RCA labs were in Camden, NJ.
If any one other thoughts or info I'd love to hear from you.
And if you've done a Pilot 602 restoration and would share the parts list, I'd be deeply in your debt.
Thanks,
John
Thanks,
John
