Great amp, the 232, any version...Sonic character is very detailed with a little warmth. This is not your average, sweet and detailed sounding EL-84 amp. The phase inverter, known as paraphase, has been accused of creating a "fast" sound with this amp. Yes, this amp does sound fast...
I have restored, fixed and used a few of these 232s. There were at least two versions, probably three or four including the unpainted, aluminum chassis from the console versions. As a stand alone amp, some jumpering is needed at that rare, 11 pin socket. The natural preamp mate is, of course the 210, which has been undervalued for some time. The Pilot 210 is quite rare to find these days. More of the console versions show up, with the "stand-up" fascia. They have the same circuitry inside as the beautiful, golden face and surround, lying down, non-console version. If you do run into a 210 console version, or any affordable 210, you will benefit from building a separate power supply for the 210.
Being aware that the 232 can be accused of not being too warm or too sweet sounding, many classic tube preamps are very good partners. An upgraded Dyna PAS is a good start. Instant step-ups can be had with slightly greater investment. Before springing for an expensive Marantz 7, consider an EICO HF-85 or the more expensive Lafayette KT-600. My fave classic is the HF-85; very versatile with a fantastic phono and very capable line stage. I did use a 232 with a late '70s Paragon E preamp for a while, but preferred the "sweeter" sound of the KT-600 or HF-85.
Modern or antique matters not...Great, quality sound can be had with all old, some new, some even solid state, even all new. Which phono stage do you now use ? Do you have a vintage mono disc collection ? The reasoning is simple...Only you can decide which you prefer. If you like a very detailed, "neutral" sound, the 232 amp is for you. If so, the preamp choices are greater, as you might actually prefer a solid state phono stage, or a more modern full function preamp. I had good results with Phase Linear 2000, 4000 and Harmon Kardon Citation A sand state preamps. The Phase Linear 2000 is quite a sleeper, BTW...
Some friends totally enjoy their Apt Holman preamp used with their tube amps. If you like the early mono discs, switchable phono EQ becomes desired. Here, the Lafayette KT-600 or a Pilot 210 would be a clear winner. If you strictly listen with stereo LPs, you would only need the "standard" RIAA phono EQ.
Concerning using a Pilot 240 integrated as a preamp is really not a great idea. Amps usually run at much higher voltages than most preamps. So, taking away the tube integrated amp's power amp stage, will have the voltages very high, indeed. That will require voltage dropping methods in the power supply to get the preamp stage "just right." Speaking of "just right," I wish the Pilot 210 actually had a good mono switch. With the 210, you can choose Stereo, Stereo Reverse, Mono L or Mono R, but not Mono L+R ! What were the designers thinking ? Well, they designed a great sounding preamp with calibrated tone controls. Plus, they got the math correct with their phono stage. The Tape Head input can easily be rewired for a dedicated phono input, with the phono EQ of your choice. If you can decipher that wiring, you can also figure how to make a true L+R mono mode connection if needed...
