pilot sa232
maxjr
Hi all
Can I safely hook a set of kg-4 speakers at 4 ohms to the 8 ohm tap on a sa-232 Thanks John:scratch2:
Thanks for the info will do. Jaymanaa did a fantastic job of rebuilding it I do not want to mess it up Thanks
Not a problem with a tube amp to run different ohm speakers on different taps,
I wouldn't add resistors or parallel resistors to the outputs for the "correct" set.
