Flobbley
Hey guys,
So I picked up a Technics M14 tape deck from Goodwill yesterday and it was working perfectly except for some hisses and clicks in the recording volume knob. So i gave it a shot of deoxit and while I was at it I cleaned the play head, pinch roller, and capstan with alcohol. Apparently that was a mistake because it doesn't play now, the pinch roller is not raising high enough to engage the capstan. I'm guessing the fix to this is just to stretch out the spring a bit that raises the pinch roller, but i figured I'd check here to see if anyone has a different solution or a way to do that without having to take apart the mechanism.
Thanks
Thanks
