I would think that this being the Pioner forum people are going to recommend the Pioneer. Maybe post it in the Sansui sectian as well... Or actually generral.
I can attest to the build of that Sansui. The thing is truly two monoblocks sharing only (the phenolic of the) circuit boards and power switch. Well, the main fuse as well I think. All the way through otherwise, even the phono preamp has separate supplies.
I haven't worked on that model Pioneer but looked it up on the engine. It has moving coil capability, which I am pretty sure the Sansui lacks. If you ever thing you are goint to pay $300 for a cartridge you might want that. However there is an IC in the power amps, which I do not like. It appears to be mainly for protection but I didn't study it all that long. I say when you can avoid ICs, avoid them.
The Pioneer has slightly more power and a hair higher damping factor. (think of damping factor as the bottom number of a fraction, like power, it takes a lot of difference in that number to be hearable, that 15 % difference in power output also means nothing)
The Pioneer uses some strange ass configuration with two transformers but it does not appear to have totally separate supplies for each channel. Not really sure what they got out of doing that really, but it is not the usual power supply. Just more current. The Sansui, each transformer seconday is center tapped, the Pioneer they are not, which means nothing sonically except that the two channels still share the same power supply.
They each have their unique good and bad points. The thing that would make e stay away form the Pioneer is those ICs in the power amp. They look to be in position to be damaged if the outputs go shorted. They are probably unobtainium.
So really, those are the facts. Nobody can really just make a firm recommendation on something like this. If phono is important to you, the Pioneer being MC capable indicates it probably has less noise and will be quieter on a MM cartridge. But the Sansui has two phono inputs.
In the end it is your call, all we can do is give you the facts.
