From the transformer right now, it measures 16.1VAC. So from what you said that would give enough headroom for it to give a good 19VDC?
EDIT: Just thought... the voltage at my house is on the high side, at 250V... if the voltage selector on the back reads 240V will I be getting a biased reading of the rated output voltages?
Well, I'm not having much luck with the transformer repair/replacement. One company quoted me but said it would cost too much to realisticly suggest doing it, and another told me that transformers can often run hot and that it could be normal. If it is, I don't want it to be getting so hot next to the amp myself... we'll see what they come up with but I'm starting to wonder what to do next. Either get a custom torroid transformer made and house it externally, or have a new EI core transformer made overseas.... any other options?
It's unbelievable how knowledge is falling down in nosedive fashion... Only someone used to work on the low quality end of the scale can say a heating up transformer could be just fine and normal LMAO ...
I was thinking there should be parts units around for this amp, it was not that uncommon. I assume you watched ebay? You can put an auto search so it will email you when keywords pop up.
