Pioneer A66X push button switch.
anderslober
Yikes...not again!
Hi forum….’subsonic’ push button switch is non-working. I have cleaned it an’all…..still no output R channel when selected.
Any ideas where to get one? Or similar? I think it is a dpdt, 6pin.
Thanks .
Best bet IMO is to ID the part and/ or board number off the service manual and try and source an OEM off the 'bay.
If you have reassembled it, you should be able to do continuity checks. If you get good signal in both positions your problem may lay elsewhere.
