Pioneer Component Serial Numbers
can anybody ID these HPM-100 as far as dates go? just got them recently. thanks in advance.
MM-YH-25399
TA-YG020645 (not sure if that's an O or a zero after the letter G).
After 21 years in storage, they're now seeing daylight again...
Spec-1 XJ3603568M
Spec-2 VK3901420M
TX-9500II XK3603577M
CT-F1000 XL3610317
PL610 YH14178T
Greetings All,
As part of our continuing effort to capture and record information for the Pioneer Component Database, we have asked for serial numbers. But, we have not focused our attention on that area. Now that the database is further along in development, we can once again look at collecting serial numbers.
So, if you can help, and do not mind moving your equipment to look behind and get the numbers, we would surely appreciate it. And, this is a great opportunity to dust off the components and clean up that wire problem. For Siamac, gathering all of his serial numbers should take only a week or so.
Again, just do a quick reply with only the model and serial number. The only way we can accomplish this is with your help.
Also, in tracking where a component was manufactured, please provide the "Made in xxxxxx" information if possible.
Thanks,
Doc and Retro Stereo
Here are Doc's numbers:
Model . . . . . Serial
RT-909 . . . . .BE 3612002
DT-500 . . . . .BB 2921042S
SA-9800 . . . . ZL 3602950M
RG-2 . . . . . .BE 3611780K
SG-9800 . . . . BC 3614862K
SD-1100 . . . . TH 1000617
PL-600 . . . . .ZG 13562
DT-500 . . . . .AJ 2912441S
TX-9800 . . . . ZE 3605139
P-D70 . . . . . EG 3607074T
CT-F1250 . . . .ZE 3600464
U-24 . . . . . .BG 1006819M
HPM-700 . . . . AK 14374U
HPM-700 . . . . AJ 11007U
HPM-700 . . . . BC 06324
HPM-700 . . . . BC 06303
SE-700 . . . . .MA 7438
SE-700 . . . . .MA 7645
DT-500 . . . . .AJ 2604970U
SM-Q300 . . . . IF 75952
MXA-1 . . . . . IF 74834
CT-F500 . . . . ZA 3687779
Project 120 . . Y 22236
Project 120 . . YD 13949
SA-6700 . . . . YA 3606248F
TX-6700 . . . . YD 3606479M
RT-1020L . . . .TL 17829
CT-F850 . . . . ZE 3605139
PD-6050 . . . . IA 3626973N
DT-550 . . . . .EI 2907763G
DT-510 . . . . .BJ 3605279G
Here is my list:
SX-636 WD3981623S. Made in Japan craigslist
SX-1010 VC1104680M. Japan bought new
CT-F9191 VH1301975. Japan bought new
RT-1050 XC2403081. Japan craigslist
A-225 JF9104702X Made in Japan
A-225 JH5500182X Made in Japan
A-400 MH9527220X Made in Japan
A-400 KE95006681T Made in Japan
TX6200 UI1509442M Made in Japan (FVZW 5 Voltage Selector Model), 1974, Sep
SA6200 TE1302712 Made in Japan (FVZW 5 Voltage Selector Model), 1973, May
TX7100 TB1600230 Made in Japan (FVZW 5 Voltage Selector Model), 1973, Feb
SA8100 UH1409570M Made in Japan (FVZW 5 Voltage Selector Model), 1974, Aug
TX9100 UI1602780M Made in Japan (FVZW 5 Voltage Selector Model), 1974, Sep
SA9100 TI1403790 Made in Japan (FVZW 5 Voltage Selector Model), 1973, Sep
Edith says:
PL 514x YI39586T Made in Japan (FVZW Model) 1978, Sep
Is there an easy way for me to find which Pioneers I have done this with? I have several more to add, just do not want to duplicate anything I have already given to you.
Ok, I'll go ahead and pass on what I have. Hopefully nothing is repeated.
SX 737-WC1116655T-Japan
SX 727-TL3750917-Japan (out of service)
SX 434-VF3909226Y-Korea
SX 434-UK3935347M-Japan
SX 1500T-OF 16131-Japan
