Rob_Feature
Rob Feature
Love this pair of speakers but one cabinet's woofer has recently started cutting out at low volume. If I turn up the volume, it stabilizes. I've swapped speakers ensuring it isn't anything earlier in the chain.
I popped off the back and the crossover (SNP-035) has 4 can caps. Does it sound like that's the most likely culprit? Should I order a couple of each and replace them in both speakers? (the caps look original).
Sound like a good plan...any other things to check first? Thanks in advance!
PS: I can't read the voltage on the smallest cap, which is 1.5uf, because it's turned in a way to make it hard to see without removal, Anyone know what voltage I should get for a replacement (dont wanna remove it until I have the replacements in hand)?
