Pioneer CS-J7001 woofer replacements.
ssawesome
I have a pair of cs-j7001 pioneers speakers but the woofers are shot on both, what are some equivalent replacement woofers and where can I find them? Not looking to break the bank. But affordable, quality sound is the primary goal.
Thank you for your help.
TBH, whatever you spend on replacement woofers is too much for these rack system speakers. That same money could probably buy a better set of used speakers, purchased locally.
Now having said that, if you decide you still want to go ahead with this project, Parts Express is usually the go-to place for reasonably priced drivers. Here are all the 12" woofers they sell (unfortunately, many of them are currently out of stock). Your best bet, IMO, would be to join the Parts Express Tech Talk forum (it may take a few days to get approved) and post your query there. In addition to the speaker model. you'll want to give the woofer size (12"; note that woofer sizes are nominal and usually measured as the frame's outside diameter, or in the case of a square frame. from frame edge to frame edge; also, you don't need to replace these with square frame woofers), internal box volume, and length and diameter of the port (you'll have to measure those). The experts there can give the best recommendation.
These are the speakers that are being discussed:
Thank you for your advice. Will look into this. May just have to eat the loss. Luckily I picked them up at 10$ for the pair.
A cheap lesson. Look around your used market and see what's available. Don't assume that anything from a manufacturer you're familiar with will be good; most (but not all) speakers from well known Japanese electronics manufacturers (e.g. Pioneer, Sony, Technics, Kenwood, Sansui) made in the 1970s through the 1990s were mediocre at best. Most of the better speakers are made by companies that specialize in them.
