AAA3330
I'll clean the belts. What is a good way to do that? I'm thinking of a q-tip with maybe some windex and clean the inside of the belt while its running. do you think that will work?
If you have some rubber rejuvinator/cleaner, you could use that. A lot of times, I'll just use some formula 409 for cleaning belts and pinch rollers. Some may beg to differ about using 409, but has worked well for me. Just spray some on a paper towel, wrap it around the belt, and pull the belt through it. May not be enough pressure using a q-tip.
