Pioneer CT-F900 control problems
scottonnob
Scott Palmer
This may be cassette deck 101 for everyone else, but it's beyond my knowledge level. I have a 900 that's been in storage for at least a couple decades. I pulled the panels and face to inspect, clean, and sleuth. After running through everything, belts were all there and turning, and the controls started to work as intended. The problem is the Play mode. With a tape out of the holder, and while pressing the sensor arm, I hit Play, the idler arm swings to the right, and the right armature spins. The left armature remains motionless. And in this configuration, the Play with continue until I either push Stop, or release the sensor arm. With a tape in the transport, I hit Play, the idler again swings to the right, the right armature typically jerks the correct direction, then abruptly stops. At the same time, the left hub is spinning, running tape across the head, after which, it just balls up once passed the right capstan, then the solenoid stops the playback. Sometimes, with a tape in the unit, I hit Play and both armatures turn normally a few rotations, but eventually the right armature stops and the solenoid again kicks everything off. Rewind and FF both work properly. It's apparently only the Play mode that is malfunctioning. The part I don't understand, and is probably obvious to everyone else is, why, in Play mode, does the left armature stay motionless without a tape in the unit, but spins with a tape in, even though the idler wheel still shifts to the right? Also, without a tape in the carriage, I hit Play and the right armature begins to spin, rather fast, and if I put my finger on it, as it's spinning, there is considerable force moving the armature. It doesn't feel as though the belt is, or would be slipping. It seems solid. I'll eventually replace all the belts, but I want to do as much diagnosis as possible, before I start ordering stuff.
Ooh, ooh, I'll take the easy one: because in play mode it is only the capstans/pinch rollers pulling on tape that causes the left reel to move. No tape, no motion.
The problem with your deck's take-up drive is pretty common. See the thread below for an excellent and very detailed guide on how to recondition the whole drive system. It involves more than just replacing belts, and is really quite a project. For starters, it involves disassembling the reel drive motor so that the brushes and rotor contacts can be reconditioned. I don't mean to be discouraging, just realistic. It can definitely be done.
https://audiokarma.org/forums/index.php?threads/rebuilding-a-pioneer-ct-f900-transport.67191/
Cheers,
chazix
Thanks. I don't mind that it's a big project. There's absolutely no hurry, and I like doing that sort of thing anyway. Sounds like fun.
There was a You tube video on how to sort the spool drive motor and burnishing the commutator and such.....
Basically Pioneer used cheap crap motors and they are prone to oxidation in the contacts inside the motor.
I did this job on the CT-F900 I had a while back, it was indeed a big project, I actually wish I'd never sold that deck, they are actually quite good...
