Maybe someone can help me with this issue: I substituted the Pioneer RXM-047 take-up motor in a CT-F950 with a new one that fits very well, 12V nominal 2400 rpm but absorbing 140mA instead of 50mA of the original one.
The question is: the driving circuit of the motor can supply with no side-effects such a current load or should I put a 100ohm resistor in series with the motor?
A second question is that after the substitution when playing the cassette the rec mode sometimes goes on even if the relevant switch is not pressed. Incredibly it goes in Rec mode more often if the rec protection tag on the cassette is removed.:worried:
I suspect that for some reasons the higher current flow has some strange effect on other part of the circuit.
Hope someone can help me.
Regards
Stefano
Regards
Stefano
