Pioneer DSS-9 Speakers Crossover Networks Recap
Pharssa
AK Subscriber
Hi,
I am considering replacing the old capacitors in my DSS-9 speaker networks. I am handy with soldering but need help identifying and ordering correct replacement parts. Each speaker has two networks. The parts list from the service manual is:
All Parts (Both Networks in a speaker)
MarkSymbol & DescriptionPart No.
—Network assembly (DSS-9)SWN-493
—Network assembly (DSS-E10)SWN-492
L1Choke coil (0.58 mH)STH-405
L2Choke coil (1.8 mH)STH-295
L3Choke coil (0.33 mH)STH-384
L4Choke coil (3.5 mH)STH-404
L5Choke coil (26.1 mH)STH-376
Br1Circuit protectorSSG-007
R1Resistor (56 Ω)RT5B560K
R2Resistor (1.8 Ω)RT5B1R8K
R3Resistor (15 Ω)RTF30150J28AL
C1Capacitor (8.2 μF)CES04DX8R2K63
C2, C5Capacitor (3.9 μF)CES04DX3R9K63
C4Capacitor (1 μF)CFS932UA105K200
C3Capacitor (3.3 μF)CFS932UA335K200
C6Capacitor (2.2 μF)CFS932UA225K200
C8Capacitor (39 μF)CES04390K63
C9Capacitor (10 μF)CE04DX100K63
C10Capacitor (10 μF)CFS932UB106K200
C11Capacitor (660 μF)SCH-004
C12Capacitor (68 μF)CES04680K63
Capacitors
MarkOriginal DescriptionPioneer Part No.Decoded / Identified TypeValue CodeDecoded ValueToleranceWorking VoltagePolarity
C1Capacitor (8.2 μF)CES04DX8R2K63Aluminum electrolytic8R28.2 μF±10%63 V DC
C2, C5Capacitor (3.9 μF)CES04DX3R9K63Aluminum electrolytic3R93.9 μF±10%63 V DC
C4Capacitor (1 μF)CFS932UA105K200Likely metallized polyester film, radial lead1051 μF±10%200 V DC
C3Capacitor (3.3 μF)CFS932UA335K200Likely metallized polyester film, radial lead3353.3 μF±10%200 V DC
C6Capacitor (2.2 μF)CFS932UA225K200Likely metallized polyester film, radial lead2252.2 μF±10%200 V DC
C8Capacitor (39 μF)CES04390K63Aluminum electrolytic39039 μF±10%63 V DC
C9Capacitor (10 μF)CE04DX100K63Aluminum electrolytic10010 μF±10%63 V DC
C10Capacitor (10 μF)CFS932UB106K200Likely metallized polyester film, radial lead10610 μF±10%200 V DC
C11Capacitor (660 μF)SCH-004Not decoded from Pioneer capacitor-code format—660 μF——
C12Capacitor (68 μF)CES04680K63Aluminum electrolytic68068 μF±10%63 V DC
Can someone help confirm the accuracy of the capacitor types and values? Also, help identify the correct replacement capacitors (BOM) to order from Mouser/Digikey or some other reliable source.
Thank you,
I recapped mine a couple of years ago. I got caps from Parts Express. Jantzen or Audyn are good quality and good value. For larger value or electrolytic, the Dayton electrolytic house brand is fine. If you got the list from the manual, you should be good. That's what l did for mine. Some values were off quite a bit. There's a big mylar cap on the woofer board I believe, that one is probably fine since they don't deteriorate as badly. I went ahead and replaced it though, since I already had the part.
@absolve2525, Any chance you still have the Parts Express part#/SKUs? Order receipts usually also have this information. If you can share it, it will greatly help. Also, did you replace some electrolytics with film capacitors or did your replace everything with the same type. Thanks
Hi,
Capacitors
Thank you,
Pm sent
How did it sound after recapping? I've got a pair and I've been thinking of doing the same as well...maybe with upgraded capacitors too. May start w/ just the ribbons and move to the mids. Complicated crossover.
