I know this thread is quite old but I just ordered the parts and have spare x-overs waiting. Will update with impressions in a week or so if everything goes well.
not quite the same, but on a pair of HPM-150 I have, I used some obbligato premium oil filled on the mids and a Dynamicap on the tweeter with an auricap on the super - did a really nice job taming the brightness.
While in there, I also replaced all of that crappy 18 gauge wiring with 12 gauge and replaced the binding posts with some real ones.
Pretty sure there wasn't any actual difference between the 100 and 200w versions. Correct me if I'm wrong.
The only differences I've seen over the years is that earlier HPM-100's had better cabinets, with drivers recessed in the baffle an little bit and held in with machine screws instead of wood screws.
The electrolytic caps will break in over time and the sound should get even better. Films don't need to break in that's why the highs are cleaner if that's what you used to replace the low capacitance 'lytic cap in each one. As for the difference to the different power rated speakers there has been and always will be the debate, but both will handle the power and are equally built. It was a matter of the change in power rating specs way back then. For some reason Pioneer decided to change the crossover on the 200w and added a silver beauty ring on the air port. The drivers are interchangeable between both. Enjoy them them and happy listening.Great thread. I spent this afternoon replacing the caps/resistors in my HPM-100's. I have one pair that were the 50W-100W versions. I picked up a pair of crossovers for 100W-200W versions and after doing the replacements on them, installed those into the 50-100W speakers.
Question: Did I need to do anything else, other than install the 100-200W crossovers to bring them to the higher levels? I believe the speakers themselves are identical are they not?
I have to admit, they sound cleaner, in that the very highs aren't as "tinny" and the lows don't tend to boom as much as they did. Maybe its my imagination, but they sure sound like they've been evened out a bit. Make sense?
Thanks for the thread to help keep these vintage pieces running!
